toothache
5kW low voltage high current inverter for industrial motor control applications
STEVAL-CTM009V1
The STEVAL-CTM009V1 evaluation kit for motor control is designed to demonstrate the capabilities of ST Power MOSFETs based on STripFET™ F7 technology. The 100 V STripFET™ F7 devices (STH31*N10F7) are ideal for low voltage (up to 48 V), high current applications such as forklifts, golf carts and power tool.
The STEVAL-CTM009V1 kit is composed of the STEVAL-CTM004V1, STEVAL-CTM005V1, STEVAL-CTM006V1, STEVAL-CTM008V1 boards which have to assembled together to build an inverter power stage for three-phase motors.
The STEVAL-CTM004V1 power board features an insulated metal substrate (IMS), NTCs for thermal protection and decoupling gate resistors for each power MOSFET. The board mounts ST devices in the H²PAK-6 package.
The driver stage is an STEVAL-CTM006V1 board with L6491 high current capability gate drivers to drive the power MOSFETs and integrated comparator for protections. The driver board includes the ST motor control connector, so you can interface the STEVAL-CTM009V1 with any ST MCU control board suitable for motor control (not included in the kit).
The system also has an STEVAL-CTM005V1 bus link capacitor board used to connect the 48 VDC power source (e.g. the battery) to manage the ripple current and an STEVAL-CTM008V1 current sensing board to read the three-phase currents and DC bus current (not assembled) thanks to the on-board ICS. The internal reference for the ICSs can be overridden by providing an external reference voltage.
Main features
  • STEVAL-CTM004V1 (power board)
    • insulated metal substrate (IMS)
    • hosts 36 STH310N10F7 or STH315N10F7 power MOSFETs in the H²PAK-6 (6x switch) package
    • Decoupling gate resistors (2.2 Ω)
    • 3-shunt resistors ground referred for current sensing (optional)
    • 3 NTCs for thermal protection
  • STEVAL-CTM005V1 (bulk capacitor board)
    • 22x 270 μF, 100 V through-hole aluminium electrolytic capacitor
  • STEVAL-CTM006V1 (driver board)
    • based on 3x L6491 gate driver with current capability up to 4 A sink/source
    • 34-pin MC connector
    • overcurrent, overtemperature and overvoltage protection
  • STEVAL-CTM008V1 (current sensing board)
    • accurate phase current sensing
    • DC current sensing (ICS not mounted)
    • possibility of overdriving VREF with an external reference voltage
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 21:12:15
  • 【Design Tools】《VHDL and Digital Circuit Design》
  • IAR-STM32 Error[Pe147]:
  • I'm looking for a question about AD sampling.
  • PC surfing the Internet via Activesync
  • IIC waveform improvement
