containsmachine
L6208 DMOS driver for bipolar stepper motor evaluation board in PowerDip package
EVAL6208N
The EVAL6208N is built around L6208 in PowerDip package. It implements a typical stepper motor driver application. Screw connectors provide connection to motor supply rail and 5 V reference for the logic inputs, as well as the four outputs to motor windings. EVAL6208N can be hooked-up to practiSPIN interface board (EVALpractiSPIN) through a 34-pin connector. It is also possible to run board in stand-alone mode: four switches are used to set the direction of the rotation, the stepping sequence and the current decay style, while four potentiometers set the L6208 reference voltage and off-time for the PWM current control; external reference voltages can be provided by a PWM output of a µC.
Main features
  • DECODING LOGIC FOR STEPPER MOTOR FULL AND HALF STEP DRIVE
  • RECTIFICATION
  • THERMAL SHUTDOWN
  • CROSS CONDUCTION PROTECTION
  • UNDER VOLTAGE LOCKOUTINTEGRATED FAST FREE WHEELING DIODES
  • FAST/SLOW DECAY MODE SELECTION
  • DUAL INDEPENDENT CONSTANT tOFF PWM CURRENT CONTROLLERS
  • OPERATING SUPPLY VOLTAGE FROM 8 TO 52V
  • RDS(ON) 0.3W TYP. VALUE @ Tj = 25°C
  • 5.6A OUTPUT PEAK CURRENT (2.8A RMS)
  • NON DISSIPATIVE OVERCURRENT PROTECTION
  • FAST DECAY QUASI-SYNCHRONOUS
  • OPERATING FREQUENCY UP TO 100KHz
Search Datasheet?
Forum More
Update:2025-08-07 00:55:19
