黄土马家
Biometric system for card proof of concept for fingerprint authenticated payment transactions
STPayBio
The STPayBio proof of concept (POC) demonstrates high performance biometric authenticated transactions based on either contact or contactless modes. A full transaction is performed in less than 1.2 s including a complete match and payment. The solution is based on the most advanced products form both STMicroelectronics, and partner to demonstrate a competitive solution with reduced bill of material (BOM). The efficient energy harvesting of the secure element is used to power all of the card companion chips including the microcontroller and the sensor.
The solution is compatible with current enrollment devices such as basic sleeve, enhanced sleeve or mobile phone applications.
The STPayBio secure microcontrollers are based on Arm® cores.Arm is a registered trademark of Arm Limited (or its subsidiaries) in the US and/or elsewhere.
所有功能
Hardware key features
Card holder identification through dual-interface card biometric system
Based on STMicroelectronics secure element (SE) and STMicroelectronics low-power silicon microcontroller
40 nm ST31 secure element:
To perform secure banking transactions, store biometric templates and carry out secure card matching
To perform energy harvesting provided by the SE with no battery, nor super cap
STM32L443 microcontroller:
To perform fast Low-power mode biometric extractions for enrollment and at each transaction
Latest generation FPC 1323 Sensor 6 contacts module on 35 mm tape
System in package (SIP) 8-pin ISO module on 35 mm tape via LINXENS
Prelam® in custom sheet formats, including RF ID1 antenna and connectivity via LINXENS
Software content
SE OS compliant with Java® Card 3.0.5 and GlobalPlatform® GPC 2.3.1 coupled with Financial configuration v1.0.2
MasterCard® applet based on M/Chip® advance 1.2.3 specification targeting MasterCard® Biometric system on chip compliancy
Proprietary enrollment applet
Extraction and matching algorithms based on fingerprint cards (FPC) libraries
Key benefits
Complete biometric system on card solution (through partners)
Reduced BOM
Matching with the secure element
High performance solution when used for both contact and contactless modes including matching.
Compatible with different enrollment processes
Easy integration with standard card manufacturers:
Hot lamination of the card body
ISO module and sensor on 35 mm tape
Yield loss reduction with module embedding at the final stage of card manufacturing
Secure solution with "False Acceptation Rate" (FAR) <1/10000 and "False Rejection Rate" (FRR) <3%
Support for validation and development
Application companion board
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:21:48
