Lemontree
12V/1A wide input range switching power supply demonstration board based on VIPER26
STEVAL-ISA081V1
The STEVAL-ISA081V1 demonstration board is a switched mode power supply (SMPS) demonstration board and it is an isolated SMPS capable of delivering a 12 W output over a wide input voltage range.
It is designed for a mains application focusing on cost and size effective solutions.
The STEVAL-ISA081V1 SMPS generates 12 V nominal output voltage using primary regulation and it is based on the VIPER26 monolithic converter, integrating a high voltage MOSFET and PWM controller in one package.
Main features
  • Vin: 85 ~ 305 Vrms / f: 45 ~ 66 Hz
  • Vout1: 12 VDC ± 10 %, 1 A (at 3.3 V not loaded)
  • Vout2: 3.3 VDC ± 4 %, 100 mA
  • Maximum total output current: 1 A
  • Standby
  • Short-circuit: protected
  • PCB type and size: FR4, single-side 35 μm, 32 x 90 mm
  • Isolation: isolated 4 kV / 8 mm
  • EMI: according to EN55022 Class
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 00:01:15
