elleny
15V, 0.15A buck converter with built-in VIPer0P offline high voltage converter
STEVAL-ISA179V1
The STEVAL-ISA179V1 evaluation board implements a wide mains range buck converter (15 V / 0.15 A), developed for general purpose applications.
The core of the application is the new VIPer0P off-line high voltage converter of the VIPerPlus family, featuring the Zero Power characteristic.
The device is a high-voltage converter that intelligently integrates an 800 V rugged power MOSFET with PWM current-mode control.
The evaluation board features a single layer design, small size, minimal BOM, high efficiency and low standby consumption.
Main features
  • Universal AC main input voltage range: 85 VAC to 265 VAC
  • Output range: 15 V / 0.15 A
  • Rated output power: 2.25 W
  • Input power in standby @230 VAC: less than 40 mW
  • Active mode efficiency: greater than 77%
  • EMI: EN55022-Class-B compliant
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:23:17
  • Ask about reentrant functions
  • Design of ACM Program-controlled Test System Based on PC/104 Interface
  • About serial communication
  • 【GD32E503 Review】01. Unboxing and Hardware Evaluation
  • Power supply interference
  • The relationship between vias and current in PCB design
