newlandmark
Evaluation board for the LD39020 high power supply ripple rejection ratio (PSRR), 200mA low dropout linear regulator (LDO)
STEVAL-ISB037V1
The STEVAL-ISB037V1 board features the LD39020 high performance linear voltage regulator, configured to convert a DC input voltage from 2.4 V to 5.5 V into a precise and stable 1.8 V output voltage.
Only two small ceramic capacitors are needed to implement the linear regulator solution.
The very low dropout LD39020 voltage regulator features high PSRR and low quiescent current in a tiny DFN4 package with a footprint of only (1 x 1) mm².
It is designed for low-power battery operated equipment such as smartphones, tablets and wearable devices.
Main features
  • Output current: 200 mA
  • Logic controlled electronic shutdown
  • High PSRR
    • 80 dB @ 1 kHz
    • 50 db @ 100 kHz
  • Quiescent current:
    • 20 μA typ at no load
    • 0.03 μA typ in off mode
  • 1.8 V ± 0.5% output voltage
  • Other voltage options available on request
  • DFN4-1 x 1 package (0.8 x 0.8 available on request)
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-27 12:34:17
