newlandmark
Teseo-LIV3F based GNSS evaluation board for SPC5 microcontrollers
AEK-COM-GNSST31
The AEK-COM-GNSST31 evaluation board is based on the certified Teseo-LIV3F global navigation satellite system (GNSS) module with embedded TeseoIII single die standalone positioning receiver IC.
The tiny, affordable, and easy-to use module guarantees superior accuracy and reduced time to first fix (TTFF) thanks to the on-board 26 MHz temperature compensated crystal oscillator (TCXO) and dedicated 32 KHz real-time clock (RTC) oscillator.
The evaluation package is used in conjunction with the X-CUBE-GNSS1 firmware to provide the necessary acquisition, tracking, navigation and data output functionality without external memory support.
The AEK-COM-GNSST31 evaluation board can be readily connected with an SPC5 MCU for automotive application development as part of the AutoDevKit™ initiative.
Main features
  • Sensitivity: -162 dBm indoor (tracking mode)
  • Interfaces:
    • UART and I²C ports
    • Configurable digital I/O timepulse
    • EXTINT input for wakeup
  • NMEA protocol
  • Assisted GNSS:
    • Predictive autonomous
    • Predictive server-based
    • Real-time server-based
  • Compatible with SPC5
  • LNA and SAW filter on the RF path
  • SMA female antenna connector
  • Battery holder
  • Highly compact design: 70 x 65 mm
  • Operating supply voltage: 3.3 - 5 V
  • Ambient temperature: -40/+85 °C
  • Part of the AutoDevKit™ initiative
  • RoHS and WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 21:39:29
  • Design of information processing and monitoring system for modern elevators
  • CC2530 wireless lighting experiment
  • About Kalman Filter Algorithm
  • Very good DSP introductory material (I)
  • Fortune China: The Secret of Huawei
  • Frequency Response of an RC Low Pass Circuit
