JFET
Fully integrated 5A NVDC single-cell battery charger with power path and MaxCharge high-voltage adapter
TIDA-00538
The bq25892 is a highly integrated switch-mode battery charge management and system power path management device for single-cell Li-ion and Li-polymer batteries used in a variety of smartphones and other portable devices with USB or high-voltage adapters. Its low-impedance power path optimizes switch-mode operating efficiency, reducing battery charge time and extending battery life during the discharge phase. An I2C serial interface for charging and system setup makes this device a truly flexible solution.
characteristic
  • ● Supports high voltage adapter to achieve maximum 5A charging current
  • ● Highly integrated solutions with maximum efficiency
  • ● Input Current Optimizer (ICO) for full adapter utilization
  • ● Provides system and battery monitoring via ADC; host control and autonomous charging (when host is unavailable)
  • ● Integrated low Rdson battery FET for long battery run time
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 08:45:03
  • A Software Engineer's First PCB
  • Ceramic capacitors from NVIDIA
  • [spartan6 report] SAR, 3G mobile network Lu, Lub interface detection
  • Ideals, passion, and survival: 20 years of work experience and insights of a technical manager (transferred)
  • WINCE 5.0 installation error
  • Problems with using modelsim
