smallembedded
Brushless DC motor with speed control
TIDA-00197
This advanced motor implements closed-loop speed control to maintain precise RPM across load torque profiles. The DRV5013 Hall-effect sensor senses the magnetic rotor position, and the DRV8308 controller determines when to drive the CSD88537ND FET that energizes the coil . Without the use of a microcontroller or firmware, the sinusoidal current minimizes noise and torque ripple, maximizing motor performance.
characteristic
  • ● Speed ​​controlled at 2054 RPM for any torque load up to 118 mNm (16.7 oz-in)
  • ●Power input supports 24V to 32V and above 5A
  • ● Outward-swing style provides good power density in 6x6x3 cm 3 form factor
  • ● RPM and maximum current can be easily modified by changing resistors
  • ● Designed to achieve efficiency up to 71%
  • ● The system has been fully tested and proven in practice
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 10:44:31
