qoistoochee128
12V and 24V brushless DC external rotary motor reference design
TIDA-00196
This 6cm motor is packaged and ready; connect to power and run! The simple and reliable design is easily modified to support speed and current system needs. The DRV5013 Hall-effect sensor senses the magnetic rotor position, and the DRV8307 controller determines when to drive the CSD88537ND FET that energizes the coil .
characteristic
  • ●Power input supports 8.5V to 32V and 5.2A or higher
  • ● Outward-swing style provides good power density in 6x6x3 cm 3 form factor
  • ● Speed, maximum current and maximum torque can be easily modified by changing resistors
  • ● Can drive 201 mNm (28.5 oz-in) (1767 RPM, 24V, 2.1A)
  • ● Designed to achieve up to 75% efficiency
  • ● The system has been fully tested and proven in practice
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 08:22:17
