王达业
Industrial smart sensor kit based on L6364W dual IO-Link device transceiver
The STEVAL-IOD04KT1 is a reference design kit that exploits the features of the L6364W IO-Link dual-channel device transceiver.
[STEVAL-IOD04KT1]
The kit consists of the STEVAL-IOD004V1 main board (not available for sale), the STLINK-V3MINI programmer and debugger tool, a 14-pin flat cable, and an M8 to M12 standard industrial connector adapter.
The kit acts as a modern smart industrial sensor to be connected to a master IO-Link hub (or a suitable PLC interface).
The power supply for the MCU, sensors, and other logic devices derives from the DC-DC converter controller embedded in the L6364W.
The on-board STM32G071EB microcontroller runs an IO-Link demo stack v.1.1, which controls the IO-Link communication, and the software code that manages the L6364W transceiver and the MEMS industrial sensors.
The tiny dimensions of the main board have been achieved thanks to the small sizes of the CSP package options of L6364W and STM32G071EB.
Connect the main board to an IO-Link master via the adapter and the M8 connector included in the kit for normal operation. Connect the same board to the STLINK-V3MINI through the flat cable only if you want to program the STM32G071EB with a new firmware.
所有功能
Kit content:
STEVAL-IOD004V1 (45.8 x 8.3 mm) main board with shape easy to be integrated in industrial sensors housing (not available for separate sale)
M8-M12 industrial connector adapter including a 20 cm cable
14-pin flat cable
Main board features:
Industrial sensor node based on STM32G071EB (mainstream Arm® Cortex®-M0+ RISC core MCU operating at up to 64 MHz frequency), L6364W (dual channel transceiver IC for SIO and IO-Link sensor applications), IIS2MDC (high accuracy, ultra-low-power, 3-axis digital output magnetometer) and ISM330DHCX (iNEMO inertial module with machine learning core, and finite state machine with digital output for industrial applications)
Runs an IO-Link v.1.1 demo-stack and MEMS control software, included in the companion package STSW-IOD04K together with the IODD file
Operating voltage range 7 to 32 V
Four-pole M8 industrial standard connector
L6364W embedded DC-DC converter provides 3.3 V supply for all on-board ICs
General-purpose LEDs for transmission, programming/debugging, warning, and status
Jumpers for CQ and DIO selection in independent or joint mode
Switch for transmission mode selection (transparent, single, or multioctet)
Reset button
10-pin connector for sensor expansion options
SWD connector for debugging and programming capability
Protections against surge pulse (up to ± 3APK with 500 Ω coupling) and reverse polarity
EMC and EMI tested according to standard requirements
RoHS compliant
Search Datasheet?
Forum More
Update:2025-08-08 02:36:01
