This circuit can adjust the audio input signal and uses the LA3600 chip to provide 5-segment circuit equalization.
Its center frequency and sensitivity are programmable
wide voltage input and can withstand 5-15V voltage without error output
high stability capacitive load
The frequency band can be changed through the capacitance from Base and NF to the total NF terminal, and the level can be changed by changing the potentiometer.
The capacitance and frequency provided by this circuit are as follows
C1( nF ) |
C2 ( nF ) |
f |
220.0000 |
100.0000 |
118.7857 |
Hz |
47.0000 |
47.0000 |
374.8673 |
Hz |
10.0000 |
33.0000 |
969.8810 |
Hz |
0.4700 |
22.0000 |
5479.1747 |
Hz |
0.2200 |
10.0000 |
11878.5677 |
Hz |
Input method: Insert the 3.5mm cable into the input terminal, and use the DIP switch to select the channel (left and right channels). The output channel is also output to the 3.5mm cable. You also need to specify the channel.
Only supports single-channel input or dual-channel mixed into single-channel input. If you want dual-channel, you can use the debug pin, which is defined as follows
Pin and female headers are optional, 1*10p
pins | network port | Definition |
1 | EQ OUT | Processed audio output |
2 | GND | commons |
3 | none | hanging in the air |
4 | GND | commons |
5 | LA Input | Left channel input |
6 | RA Input | Right channel input |
7 | GND | commons |
8 | VCC | power input |
9 | null | hanging in the air |
10 | null | hanging in the air |
Plug in the 9-18V power supply from the debug pin or power socket, plug it into the audio interface, and adjust the input and output channels to connect to the power amplifier.
This project is an original project and is being made public for the first time. It will only be made public on the Lichuang open source platform.
It is prohibited from being sold as a commodity under the GPL3.0 agreement and is only for learning, education and other purposes.
This project complies with the GPL3.0 agreement and is not for commercial use. It is only used for learning and education. Secondary creation is allowed, but after the second creation, it must be open source under the same agreement.
To make up for the audio shortcomings, LA3600 five-band equalizer chip is added, using DIP-16 package.
wide voltage input, which can withstand 5-15 volts without error and output
high stability capacitive load.
This is its pin definition
pins |
definition |
Definition |
1/3/5/7/9 |
Base1-5 |
Fundamental frequency setting |
2/4/6/8/10 |
NF1-5 |
Frequency reference terminal |
16 |
GND |
commons |
15 |
DC |
Decoupling capacitor |
14 |
VCC |
power supply |
13 |
OUT |
Output |
12 |
NF |
total reference terminal |
11 |
IN |
Input |
Base is broken and a capacitor is connected in series to the nf terminal,
and then a capacitor is connected in series to the potentiometer to the total reference terminal
to achieve center frequency adjustment.
If you want to achieve more segments of adjustment, connect the output terminal of the upper stage LA3600 to the input terminal of the next stage, and adjust C1 and C2 to adjust different center frequencies.
Center frequency calculation formula:
This project has no peripheral software
According to BOM list
ID | Name | Designator | Footprint | Quantity | Manufacturer Part | Manufacturer | Supplier | Supplier Part | Price | Pins | JLCPCB Part Class | Contributor | Description | link |
1 | 220nF | C1 | C1210 | 1 | C1210X224K451T | Holy Stone Enterprise | LCSC | C340313 | 1.0293 | 2 | LCSC | https://item.szlcsc.com/364452.html | ||
2 | 47nF | C2 | C1206 | 1 | CC1206KKX7RABB473 | YAGEO | LCSC | C327004 | 0.2205 | 2 | LCSC | https://item.szlcsc.com/89171.html | ||
3 | 10nF | C3 | C1206 | 1 | C1206C103K5RAC7800 | KEMET | LCSC | C141181 | 0.1385 | 2 | Extended Part | LCSC | https://item.szlcsc.com/89171.html | |
4 | 470pF | C4 | C1206 | 1 | CC1206KRX7RYBB471 | YAGEO | LCSC | C107212 | 0.1117 | 2 | Extended Part | layout | https://item.szlcsc.com/89171.html | |
5 | 10nF | C5 | C1206 | 1 | 1206B103K102NT | FH | LCSC | C9194 | 0.1076 | 2 | Extended Part | layout | https://item.szlcsc.com/89171.html | |
6 | 100nF | C6 | C1206 | 1 | 1206B104K101 | WTC | LCSC | C77502 | 0.1559 | 2 | layout | https://item.szlcsc.com/89171.html | ||
7 | 47nF | C7 | C1206 | 1 | CC1206KRX7R9BB473 | YAGEO | LCSC | C107209 | 0.2785 | 2 | Extended Part | layout | https://item.szlcsc.com/89171.html | |
8 | 33nF | C8 | C1206 | 1 | CC1206JRX7R0BB333 | YAGEO | LCSC | C527315 | 0.3092 | 2 | LCSC | https://item.szlcsc.com/89171.html | ||
9 | 22nF | C9 | C1206 | 1 | 1206B223K500CT | Huaxin S&T | LCSC | C296114 | 0.1387 | 2 | LCSC | https://item.szlcsc.com/89171.html | ||
10 | 220pF | C10 | C1206 | 1 | 1206N221J101CT | Walsin Tech Corp | LCSC | C396803 | 0.1744 | 2 | LCSC | https://item.szlcsc.com/89171.html | ||
11 | 12Vin | DC1 | DC-IN-TH_DC-470-2.1GP | 1 | DC-470-2.1GP | GANGYUAN | LCSC | C194407 | 0.4 | 3 | Extended Part | LCSC | https://so.szlcsc.com/global.html?c=&k=C194407 | |
12 | 47uF | C17 | CAP-TH_BD6.3-P2.50-D1.0-FD | 1 | 47uF 50V 6.3*11 | ValuePro | LCSC | C45101 | 0.1078 | 2 | Extended Part | Official package library | https://item.szlcsc.com/44807.html | |
13 | 22uF | C18 | CAP-TH_BD5.0-P2.00-D0.8-FD | 1 | 22uF 50V 5*11 | ValuePro | LCSC | C43346 | 0.0736 | 2 | Extended Part | Official package library | https://item.szlcsc.com/44805.html | |
14 | 3.3uF | C19,C21 | CAP-TH_BD6.3-P2.50-D1.0-FD | 2 | 47uF 50V 6.3*11 | ValuePro | LCSC | C45101 | 0.1078 | 2 | Extended Part | Official package library | https://item.szlcsc.com/44807.html | |
15 | 1000 | C20 | CAP-TH_L8.0-W4.0-P5.00-D0.7 | 1 | R08B1B102KN0B0S0N0 | Songtian Elec | LCSC | C249166 | 0.1964 | 2 | Extended Part | LCSC | https://item.szlcsc.com/265363.html | |
16 | Input | CN2 | AUDIO-TH_PJ-3136-B | 1 | PJ-3136-B | XKB Enterprise | LCSC | C381131 | 0.5242 | 6 | Extended Part | Lichuang EDA official packaging library | ||
17 | Pin header and female header 1*10P | H2 | Pin header and female header 10P | 1 | - | Shenzhen Cankemeng | LCSC | C35445 | 0.8744 | 10 | PQG2030PQG | |||
18 | 110Hz | R20 | RES-ADJ-TH_RK09L1140A5P | 1 | RK09L1140A5P | ALPSALPINE (Alps Alpine) | LCSC | C124974 | 7.64 | 5 | Lichuang EDA official packaging library | https://item.szlcsc.com/231612.html | ||
19 | 375Hz | R21 | RES-ADJ-TH_RK09L1140A5P | 1 | RK09L1140A5P | ALPSALPINE (Alps Alpine) | LCSC | C124974 | 7.64 | 5 | Lichuang EDA official packaging library | https://item.szlcsc.com/231612.html | ||
20 | 969Hz | R22 | RES-ADJ-TH_RK09L1140A5P | 1 | RK09L1140A5P | ALPSALPINE (Alps Alpine) | LCSC | C124974 | 7.64 | 5 | Lichuang EDA official packaging library | https://item.szlcsc.com/231612.html | ||
twenty one | 5480Hz | R23 | RES-ADJ-TH_RK09L1140A5P | 1 | RK09L1140A5P | ALPSALPINE (Alps Alpine) | LCSC | C124974 | 7.64 | 5 | Lichuang EDA official packaging library | https://item.szlcsc.com/231612.html | ||
twenty two | 11878Hz | R24 | RES-ADJ-TH_RK09L1140A5P | 1 | RK09L1140A5P | ALPSALPINE (Alps Alpine) | LCSC | C124974 | 7.64 | 5 | Lichuang EDA official packaging library | https://item.szlcsc.com/231612.html | ||
twenty three | 180 | R25 | RES-TH_BD2.5-L6.5-P10.50-D0.6 | 1 | MFR0W4F1800A50 | UniOh | LCSC | C58665 | 0.0559 | 2 | Extended Part | Lichuang EDA official packaging library | https://item.szlcsc.com/204066.html | |
twenty four | 10K | R26 | RES-TH_BD2.5-L6.5-P10.50-D0.6 | 1 | MFR0W4F1002A50 | UniOh | LCSC | C57436 | 0.0538 | 2 | Extended Part | Lichuang EDA official packaging library | https://item.szlcsc.com/204066.html | |
25 | 4.7K | R27 | RES-TH_BD2.5-L6.5-P10.50-D0.6 | 1 | MFR0W4F1002A50 | UniOh | LCSC | C57436 | 0.0538 | 2 | Extended Part | Lichuang EDA official packaging library | https://item.szlcsc.com/204066.html | |
26 | LA3600 | U5 | DIP16 | 1 | LA3600 | 16 | Varadha_Eda | 5Band Graphic Eq. | ||||||
27 | Input channel | SW1 | KEY-TH_4P-L6.0-W6.2-P2.54-LS7.62-BL | 1 | KF1027A-02P-LG-ON-01B | kaifeng | LCSC | C976334 | 1.487 | 4 | LCSC | https://atta.szlcsc.com/upload/public/pdf/source/20201230/C976343_CACF45B35FFD28514ED564B10108BF0E.pdf | ||
28 | Output channel | SW2 | KEY-TH_4P-L6.0-W6.2-P2.54-LS7.62-BL | 1 | KF1027A-02P-LG-ON-01B | kaifeng | LCSC | C976334 | 1.487 | 4 | LCSC | https://atta.szlcsc.com/upload/public/pdf/source/20201230/C976343_CACF45B35FFD28514ED564B10108BF0E.pdf | ||
29 | PJ-3136-B | CN3 | AUDIO-TH_PJ-3136-B | 1 | PJ-3136-B | XKB Enterprise | LCSC | C381131 | 0.5242 | 6 | Extended Part | LCSC |
There is Lichuang Mall’s logo on the front and back:
See attachments and: [Demonstration video] 5 Bacteria-Breaking and Balancing Qi + Yin Xiang_bilibili_bilibili
