qoistoochee128
SATA hard drive backplane
In order to make it easier to change disks at any time, I made a motherboard
that supports hot swapping. It is really convenient.
All the things are available on a certain treasure, and the price is much lower than the ones bought at Huangyu.
#First
update:
put Things to note when changing the soldering point to an IDE interface
1. There is no 3.3V power supply. If necessary, open the PCB design drawing to add it
. 2. The IDE (large 4pin) is used to convert to Sata. There is no spare IDE interface and needs to be changed to Sata
. 3. I only tested using two 1t units at the same time. I don’t know if a larger one can drive
4. The positions of the Snail Star and other chassis are not necessarily correct. They are designed according to the front panel of the old Parkson chassis. Other chassis need to be adapted by themselves.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 21:37:44
