JFET
JQ8400 voice module
The JQ8400 voice module uses a SoC solution, which integrates a 16-bit MCU and an ADSP specifically for audio decoding. It uses hard decoding to further ensure the stability and sound quality of the system. The compact size better meets the needs of embedding in other products. SPI-flash replaces voice content. The biggest advantage of this chip is that it can flexibly replace the voice content in SPI-flash, eliminating the trouble of traditional voice chips that need to install a host computer to replace the voice. SPI FLASH directly simulates a U disk and copies the U disk. - Like, very convenient. Making product development and production convenient and simple. One-line serial port control mode and RX232 serial port control are optional, providing more selectivity for R&D 1. Supports all bit rates 11172-3 and IS013813-3 Layer3 audio decoding MP3 file formats 2. Sampling rate support (KHZ): 8/1 1.025/12/16/22.05/24/32/44. 1/48 3. Supports Normal, Jazz, Classic, Pop, Rock and other sound effects. USB interface: 2.0 standard UART connection: -wire serial port, standard serial port, TTL power Level input voltage: DC3.3-5.5V, the best limit is 4.2V, 10 level is 3.3V Rated current: sleep current: 500uA, working current: 10mA Working temperature: -40 degrees ~ 85 degrees
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 12:48:52
