张三叔
Type-C WH
The adapter component is designed based on the 0jcxg0 module, and a high-performance USB2.0 hub is integrated inside, eliminating the need to connect two wires and making the connection stable.
It is recommended to default to 1.6 for the upper board and 1.2~0.8 for the bottom board. Since the module adopts a back-soldering design, it is not recommended to choose 1.2 or above for the bottom board, and the minimum is 0.8. Otherwise, the finished product will not be strong enough.
It is recommended to use medium temperature solder paste with an air gun or constant temperature soldering station for the entire board, which can improve the yield rate.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 03:52:27
