黄土马家
Button switch panel
A simple button switch board controls the Bluetooth audio switch.
For filtering, a bunch of capacitors are added. The switch is an idle button switch. In order to use the PCB as a housing, the large hole and the round head of the button switch are designed to be symmetrical.
A 6v, 3a self-restoring fuse is added for circuit protection. Since this model module is not included in the schematic diagram, a 0r resistor is used instead, but the pads are the same.
An LED was added for the power indicator light. In order to reduce the brightness, a resistor with a larger resistance was used. It turns out that the 11k resistor can still light up. No wonder it was so bright with a resistor of several hundred ohms before.
1. Blank board display
2. What it looks like after welding
3. Add a blank pcb as the base
4. Add a blank pcb as the top board
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 13:29:24
