张小哥
ESP32_Py_Board
There is a bracket next to each component, and the array inside the bracket indicates the pins used by the device. For example, the button HEY4 uses pin 18.
Features:
Onboard CH340K serial port chip supports automatic downloading. 240*240SPI display, temperature sensor DS18B20, temperature and humidity sensor DHT11, RGB three-color lamp, WS2812 lamp beads, buzzer, infrared thermal sensor, photoresistor, infrared transmitter/receiver, micro button, touch button, some IO lead out.
Display driver:
The display screen uses a Zhongjingyuan SPI interface screen with a resolution of 240*240 and a full-color LCD.
The pin wiring is as follows:
BLK ----- 23
DC ----- 22
SCL ----- 21
SDA ----- 19
RST ---- 17
Drivers can be found at:
https://pan.baidu.com/s/1nF34QoV9Dh_59AWkbowwGQ Extraction code: 8888
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 12:35:25
  • I failed the CET-4
  • The function simulation is correct, but it is not correct after downloading. Why?
  • What are the advantages and disadvantages of double-layer PCB and multi-layer PCB?
  • ZTXZTX talks about lead-acid battery maintenance
  • 8086 address offset problem
  • True 100m dual-mode Bluetooth
