张小哥
CH559L minimum system board
CH559L Minimum System Board
The smallest system board based on Qinheng CH559L, with all IO/HUB leads, and can be connected to an external crystal oscillator. QQ picture 20210725111853.jpg
Introduction to CH559L
The CH559 chip is an enhanced E8051 core microcontroller compatible with the MCS51 instruction set. 79% of its instructions are single-byte single-cycle instructions, and the average instruction speed is 8 to 15 times faster than the standard MCS51.
CH559 supports the highest system frequency of 56MHz, built-in 64K program memory Flash-ROM, 256-byte internal iRAM and 6K-byte on-chip xRAM. Some xRAM supports DMA direct memory access.
CH559 has built-in ADC analog-to-digital conversion, 4 sets of timers and PWM, dual asynchronous serial ports, dual SPI and other functional modules, as well as a built-in dual-port Root-HUB, supporting USB-Host host mode and USB-Device device mode.
STC has gone up like crazy, and just buying one piece is not as affordable as buying Qinheng.
Board introduction
Pure's smallest system board, the U number is only ranked 1.
characteristic:
  • Chip independent power switch
  • 5V/3.3V/chip power supply indicator LED
  • Onboard 500mA fuse
  • An external crystal oscillator pad is reserved to facilitate the development of projects that require an external crystal oscillator.
  • Download/reset button
  • Three independent LEDs are connected to PWM1-3 respectively and can be used as operating indicators.
  • USB Hub/Device interface lead out
Note: The chip is powered by 3.3VLDO output.
sell
The CH559L third-party firmware library is being updated. Welcome everyone to play with the Gitee link.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:20:18
