super_star
RGB keyboard eight lights
RGB keyboard eight lights uniformly illuminate the middle axis, usually used on the axis of personalized keycaps
Gerber is included in the attachment and can be downloaded directly. You can directly make the PCB in Jiali Chuanghuang. If you want to make it yourself, you can just make 5 pieces for 5 yuan and just buy the lamp on Taobao and weld it.
It is recommended to use a heating table for soldering. If you are skilled in soldering iron, there will be no problem in soldering. The purchase links for lamp beads and heating tables are below. It’s just that I have no interest in the links I purchased.
Lamp bead link: https://item.taobao.com/item.htm?spm=a1z09.2.0.0.4fde2e8disYXvu&id=618502050205&_u=g201g3gisp7afe Heating table link: https://detail.tmall.com/item.htm?id= 609967185418&spm=a1z09.2.0.0.4fde2e8disYXvu&_u=g201g3gisp61e8 solder paste link (very little used!): https://detail.tmall.com/item.htm?id=555299274372&spm=a1z09.2.0.0.4fde2e8disYXvu& _u=g201g3gispe2a8 Specific welding operations You can go to Wanmian B station to learn!
Using 8 4020side packaged ws2812, even distribution makes the light even and soft.
RGB can be programmed by itself to achieve various colors and lighting effects. It is usually connected to the reserved light strip on the keyboard PCB or flying wires to other RGB lights on the PCB.
The cost of a single piece is about 4 yuan!
Physical map
renderings
![8PCHUC3JM(1)FTR@G9TXK]N.png]
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-07 20:53:46
