super_star
Simple electronic load
The operational amplifier collects the voltage on the current detection resistor and the adjustable resistor reference voltage division to determine whether to switch the MOS to realize the constant current discharge function. Limited by the MOS thermal power and thermal resistance, a single MOS can only If it can reach about 120W, the constant current effect will be lost (the detailed parameters are forgotten). It is recommended to be powered by battery. It is not limited to the load power supply. The cooling fan uses an NTC thermistor to detect the temperature and turns on.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 21:35:05
