王达业
Debugging gadgets, a large collection of Bluetooth&hid&serial&hub
21IC link: https://bbs.21ic.com/icview-2946530-1-1.html  , both sides are the same. This debugging board comes with an SL2.1A 1 to 4hub, one of which is connected to stm32, and the remaining 3 leads can be connected to 3 USB devices. Each USB port has a 2A current limit to prevent short circuits. Comment 2020-04-21 011125 (2)_LI.jpg
There is a Bluetooth BLE device onboard, the Bluetooth chip is BC7601, connected to stm32 through spi, Bluetooth module.gif
Use stm32 to simulate hid device to realize information exchange between computer and stm32 stm32.gif
And it leads to two serial ports, an 8-channel level input/output, a 3-channel PWM output, one of which is an independent output, two channels of same-frequency output, and a set of SPI. Reasonable use can drive many peripherals. Comment 2020-04-21 011125 (5).jpg And both the serial port and IO input and output ports use isolation or level conversion, supporting 1.6~5.5V level. The board provides 3.3V and 5V level drive options, and can also provide power from the outside. The PWM and SPI interfaces are fixed at 3.3V. Output, supports 5V level input, single SPI only serves as the main device. The 8 IO ports use TVS diodes with a voltage limit of 5.5V to prevent external input reverse connection and overvoltage.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 03:41:12
