黄土马家
OLED display module-0.96 inch (7PIN)
product description
      OLED display module - 0.96 inches (7PIN), this module uses SSD1306 as the main chip, the pixel is 128*64, the communication method can be SPI or IIC (the address defaults to 0x78), the pins are fully compatible with IIC (that is, when set to IIC mode , can only connect 4 wires), the default is 4-Wire SPI communication mode, self-illuminating, free viewing angle, low power consumption.
  • Compatible with 3.3V or 5V power input
  • Compatible with 3.3V or 5V IO port level
  • Communication method can choose SPI (4-Wire or 3-Wire)/IIC
Pin function table
symbol GND VCC D0 D1 RES DC CS
describe Ground pin Power input pin clock input Data input/response output Reset signal input Data/command selection input Chip select pin
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 01:12:08
