他们逼我做卧底
Microcontroller minimum system board-IAP15W4K58S4
product description
       The use of enhanced 51 microcontroller makes the module more simple and easy to use while having high performance. The hardware supports practical peripherals such as ADC, PWM, SPI, CCP, and serial ports. It is also compatible with the Arduino UNO R3 interface and is compatible with more modules. It is a good helper for microcontroller learning.
  • This module uses 51 microcontroller, model is IAP15W4K58S4.
  • Integrated USB to serial port (TTL) circuit, can be used independently.
  • 5V, 3.3V, and GND pin headers are reserved to power external modules.
  • Three independent buttons and two independent LED indicators for convenient experimentation.
  • There are four sets of expansion interfaces for easy connection of external modules.
  • The power supply of the microcontroller can be selected from 3V or 5V, and a power consumption test interface is reserved.
  • There are two ways to download programs, cold start download and automatic download.
  • There is a four-wire OLED interface with IIC communication method.
  • Compatible interface for Arduino UNO R3.
    Pin function table
    symbol describe
    P0.0-P0.7 P0 port of the microcontroller, a total of 8 IO ports
    P1.0-P1.7 P1 port of the microcontroller, a total of 8 IO ports
    P2.0-P2.7 P2 port of the microcontroller, a total of 8 IO ports
    P3.0-P3.7 P3 port of the microcontroller, a total of 8 IO ports
    P4.0-P4.7 P4 port of the microcontroller, a total of 8 IO ports
    P5.0-P5.5 P5 port of the microcontroller, a total of 8 IO ports
    RESET cold start button
    P1 USB-MINI-B type USB female connector
    S1 Module power switch
    P2 USB-serial (TTL) interface
    P3 Microcontroller voltage selection interface
    iUSB Module overall current measurement interface
    P23 Reserved 5V, 3.3V, GND interfaces
    P18-P21 4 sets of expansion interfaces
    P17 OLED interface for four-wire IIC communication
    P9 Arduino UNO R3 interface
    P10 Arduino UNO R3 interface
    P11 Arduino UNO R3 interface
    P12 Arduino UNO R3 interface
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 09:32:27
