aytwartoofyoroo
7.4V lithium battery overcharge and overdischarge protection board
product description
     This module uses HY2120CB as the core to realize over-discharge protection and over-charge protection for dual-cell series lithium batteries . When discharging: When the lithium battery is discharged to about it will no longer discharge to prevent over-discharge; when charging: When the lithium battery is charged to about 8.4V, it will no longer be charged to prevent overcharging. Note: Overcharging/over-discharging is very harmful to lithium batteries and will cause them to heat up, burn or be scrapped.
  • Protection battery: double series lithium battery
  • Module interface: terminal blocks, XH connectors, solder pads, etc.
  • Indicator light: When the module protection function is activated, the indicator light lights up
  • Button: Just connect the battery, press the button to activate the over-discharge protection chip
Pin function table
symbol describe
P1 7.4V lithium battery input terminal (B-, BM, B+)
P2, P3 B-, B+ input terminal (6V~8.4V)
button Just connect the battery, press the button to activate the over-discharge protection chip
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 06:57:40
