smallembedded
Temperature and humidity sensor module-DHT11
product description
      The DHT11 temperature and humidity sensor module is based on the DHT11 temperature and humidity sensor. It already contains calibrated digital signals and can measure ambient temperature and relative humidity. It has extremely high reliability and excellent long-term stability. The module has a power indicator light.
product description
  • Measuring relative humidity range: 5~95%RH
  • Measuring temperature range: -20~60℃
  • Support 3.3V~5.5V DC working voltage
  • With power indicator light
    Pin function table
    symbol GND VCC DAT
    describe Ground pin Power input pin Data output pin
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 19:40:16
  • Interference issues with Bluetooth and analog audio amplification
  • What FPGA do you all use?
  • Questions about signaltap
  • 【Knowledge Sharing】The 20th issue of the excellent topic/reply activity has begun~~
  • Regarding PCB design, give a suggestion
  • 6410 New platform, burning error
