sigma
LARDUINO NANO
3.jpg2.jpga.gif Domestic LGT8F328P chip, compatible with Atmega328p chip.
The pin size sequence is compatible with Arduino NANO.
It adopts TypeC interface and the USB to serial port uses CH340K chip.
The use of cylindrical crystal facilitates manual welding.
Export all GPIOs.
Lead to the SWD simulation interface. Can be used as AVR core board.
Because the NANO and UNO chips are the same, the BootLoader is also the same.
For usage methods, please refer to the Larduino UNO domestic chip compatible board.
Before welding chip components, you can use masking tape to stick the plug-in pads to avoid the trouble of plugging holes with your hands.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 01:22:28
  • Did you feel disappointed after watching Avengers 4?
  • Trends in charging inverters
  • HDB3 encoding and decoding principle
  • Global variables
  • Help! Which sensor is best to use to make the second robot follow the path of the first robot?
  • Focus on IC design base model innovation
