王达业
Digilent HS3 Downloader
HS3 downloader based on FT232HL, tested on my Xilinx development board and available
With level conversion, it should be able to support some low-voltage boards
Four-layer board design (because there is a coupon...
Then there is a small problem with this version. If the horn base in the picture is used, the silk screen defined by the top pins will be blocked. .
The hardware reference is  https://oshwhub.com/EAFJLDSKF/digilent-hs3
For software, see  https://github.com/LE-TOM/JTAG-HS3
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-02 15:05:56
