JFET
# Sixth Lichuang Electric Competition #Desktop amplifier
* 1. Introduction to project functions
This design is a two-channel desktop power amplifier based on the LM1875 power amplifier chip.
*2. Project attributes
The project is made public for the first time; the project is original; the project has not won any prize in other competitions; it has not participated in any defense in school.
* 3. Open source agreement
This design is under the GPL3.0 open source license
*4. Hardware part
The main body of this amplifier is two LM1875 chips. The chip has excellent performance and can reach an output power of 25W under a 8 ohm load of plus or minus 25V power supply, which can be used in a small room. Regarding the circuit, we refer to the circuit in the TI chip manual and set an amplification factor of 21 times. You can also get appropriate output power by directly using a mobile phone as the audio source. The feedback network uses Panasonic's 0.1% precision electrical chip resistors, which can reduce the PCB area and the wiring length of the feedback network to reduce the introduction of noise, and also improve the symmetry of the left and right channels. Four film capacitors are connected to the rectifier bridge of the power supply to eliminate diode noise. The main filter capacitor is a pair of Panasonic 4700UF electrolytic capacitors. The main capacitor is a small film capacitor to filter out high-frequency noise. A decoupling capacitor group is also added near the power supply pin of each chip to provide a good power supply condition for the power amplifier. A protection circuit based on UPC1237 is added to the output end of the power amplifier. Its main function is to eliminate the impact of the power amplifier on the speaker when the power is turned on and to disconnect the connection between the power amplifier and the speaker when the power amplifier outputs a DC voltage fault to achieve the purpose of protecting the speaker.
*5. BOM list
ID Name Designator Footprint Quantity BOM_Manufacturer Part BOM_Manufacturer BOM_Supplier BOM_Supplier Part
1 2.2uF C1,C30 CAP-TH_BD8.0-P3.50-D0.6-FD 2
2 47uF C2,C32 CAP-TH_BD8.0-P3.50-D0.6-FD 2
3 0.1uF C3,C4,C13,C31 CAP-TH_L7.2-W2.5-P5.00-D0.6 4
4 0.22uF C5,C11 CAP-TH_L7.2-W6.0-P5.00-D0.5 2 PE224J2A0501 KYET LCSC C393118
5 100uF C6,C7,C14,C29 CAP-TH_BD8.0-P3.50-D0.6-FD 4 EEUFM1H101 PANASONIC LCSC C128473
6 15pF C8,C9,C10,C12 C0805 4 CC0805JRNPO9BN150 YAGEO LCSC C107110
7 4700uF C15,C16 CAP-TH_BD18.0-P7.50-D1.2-FD 2 ECA1VHG472 PANASONIC LCSC C178403
8 100uF C17 CAP-TH_BD6.3-P2.50-D1.0-FD 1 ERS1VM101E12OT AISHI LCSC C106694
9 223 C18 CAP-TH_L7.2-W2.5-P5.00-D0.6 1
10 47uF C19,C20 CAP-TH_BD5.0-P2.00-D0.8-FD 2 KM470M035C110A CapXon LCSC C74117
11 10uF C21 CAP-TH_BD5.0-P2.00-D0.8-FD 1 10uF 25V 5*11 ValuePro LCSC C43347
12 220uF C22 CAP-TH_BD8.0-P3.50-D0.6-FD 1 ERE1VM221F12OT AISHI LCSC C106510
13 100nF C27,C28 CAP-TH_L7.2-W2.5-P5.00-D0.6 2 C242A104J2SC000 FARATRONIC LCSC C280716
14 10nF C33,C34,C35,C38,C39,C40 CAP-TH_L7.2-W2.5-P5.00-D1.0 6
15 GBU8K D1 GBU_4P-L22.0-W3.5-P5.08 1
16 1N4007_C727081 D2,D6,D7 SMA_L4.4-W2.8-LS5.4-RD 3 1N4007G-T Diodes Incorporated LCSC C516593
17 G2R-2-DC12V K1 RELAY-TH_G2R-2-DCXX 1 G2R-2-DC12V Omron Electronics LCSC C48903
18 2A5G3HD01 LED LED1 LED-SMD_L5.0-W2.7-FD 1 2A5G3HD01 LED KENTO LCSC C3649
19 1M R1,R7 R0805 2 ERA6AEB105V PANASONIC LCSC C445668
20 22K R2,R10 R0805 2 ERA6AEB223V PANASONIC LCSC C445659
twenty one 1K R3,R15 R0805 2 0603WAF1001T5E UniOh LCSC C21190
twenty two 20K R4,R6,R8,R9 R0805 4 ERA6AEB203V PANASONIC LCSC C473304
twenty three 1R/2W R5,R18 RES-TH_BD5.0-L15.5-P19.50-D0.7 2 MFR02SF100KA10 UniOh LCSC C69885
twenty four 56K R11,R14,R19 R0805 3 PTFR0805B56K0N9 ResistorToday LCSC C351560
25 10K R12 R0805 1 AC0805DR-0710KL YAGEO LCSC C723677
26 3.9K R13 R0805 1 RK73H2ATTD3901F KOA Speer Elec LCSC C317270
27 2K R16 R0805 1 RMC08052K5%N Tyohm LCSC C269731
28 10R/2W R17 RES-TH_BD4.5-L11.5-P15.50-D0.7 1 - Chian Chia Elec LCSC C119561
29 LM1875L-TB5-T U1,U2 TO-220-5_L10.5-W15.5-P1.70-TL 2 LM1875T/NOPB TI LCSC C9666
30 UPC1237 U3 SIP-8_L19.2-W2.8-P2.54-L 1
31 7812 U4 TO-220-3_L10.0-W4.5-P2.54-L 1 MC7812BTG ON LCSC C45387
32 DB128L-5.08-2P U5,U8,U9,U10 CONN-TH_2P-P5.08_DB128L-5.08-2P 4 DB128L-5.08-2P DIBO LCSC C395868
33 DB128L-5.08-3P U6 CONN-TH_DB128L-5.08-3P 1 DB128L-5.08-3P DIBO LCSC C395869
* 6. Demonstrate your project and record it as a video for uploading
More details: https://diy.szlcsc.com/posts/06c94d90c2c447dfbd9ed7339ff4a5b1
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-26 17:44:10
