super_star
Multi-channel signal acquisition board
  • The onboard MCP1703AT-3302E/CB high-performance 3.3V linear voltage regulator can work when inputting 5V voltage, ensuring the stable and reliable operation of the signal acquisition module.
  • The onboard LM2776DBVR high-performance switched capacitor inverter generates a standard negative voltage and supplies it to the op amp module, ensuring that the amplifier module is stable and reliable without distortion.
  • For multiple input signals, two CD4051BM96  analog multiplexers/demultiplexers are installed on the board to call the input signals in a time-sharing manner, ensuring multi-channel acquisition of up to eight signals.
  • The modulation and transmission of the front-end signal relies on the rear-stage STM32 microcontroller for configuration. The two are directly connected through the DIP-7 bent needle and bent female, realizing the modular construction of the acquisition system.
  • The control signals of the subsequent stage to this module are only three decoding signals.
  • The output signal sent to the rear stage by this module includes one channel of 8-selected 1 amplified original signal; and two channels of frequency measurement signals, FRE1 and FRE2.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-17 14:43:03
