王达业
Variable gain amplifier AD8367
 The variable gain amplifier AD8367, after our verification, has obvious controllable effect in practice. Although two chips were burned when we first made it, one of it can be used in the end. Although the 0603 project was not very easy, we succeeded in the end. We used about five jumper caps, closed the control voltage terminal, performed a single-ended test, and then performed a double-ended test. The final result was ideal. The test The picture is not attached because I need to prepare some other modules to take you to the game and time is a bit tight. The project will be updated later.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 11:01:56
