3228
Lichuang EDA circuit test board (plug-in type)
Lichuang EDA has designed two very practical circuit test boards, which are divided into plug-in circuit test boards and chip device test boards. This is a plug-in test board.
You can modify and adjust it according to your own needs, or you can use it directly as a prototype.
(1) The large square of the plug-in verification board is a suspended part, which is used to connect the pins of each device and can be fixed with solder;
(2) The small dot is the ground terminal, which is convenient and simple. You can bend the plug-in pin for soldering testing;
(3) This verification board is very convenient to replace components and is easy to weld and debug.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-09 02:53:01
  • Detailed tutorial of microcontroller e-book
  • Please give me some information about MFC Bluetooth programming!
  • keyboard scancodetovirtualkey
  • wince read xml problem
  • LPC1114 serial port data reception lost
  • Why can't my laptop use ew430-3.41a?
