An appearance modification based on ATmega SolderingStation SMD v2 - EasyEDA , making it more friendly to common 88*38 shells
First of all, this all stems from my need for a T12 soldering iron, so this project almost started from scratch. Here I will tell you about the production process and precautions of this project.
First of all, I have prepared a time schedule for making this project for everyone.
Find out whether this project meets your needs |
Start modifying the customized PCB based on this project ( customize your own component layout based on the front panel ) |
Start ordering PCB |
Start ordering missing IC resistors and capacitors |
Start purchasing heating head related components power supply (24V/3A) shell ( front and rear panels ) |
PCB welding, DEBUG, program burning, and testing |
First, let me introduce this project. This project was originally submitted on EasyEDA by a big guy named Wagminator.
There are two versions of the program, one is his own original, and the other is the UI modified version of createskyblue. The scalability of these two programs is already relatively small, because Flash takes up a lot of space and there is not much room for modification.
Including slight modifications to the pin definitions on the hardware, an NTC resistor inside the handle is connected to ADC2. Interested friends can follow along and modify the program content.
What deserves more attention is the switch of this hardware
This project uses an m328 chip as the main control, with an external OLED screen and rotary encoder. The hardware supports handle vibration sleep. The hardware also has temperature feedback from the NTC inside the handle. The soldering iron tip is grounded to prevent the switching power supply from being hot or cold. Problems caused by poor isolation performance
The hardware switch uses an N-CH MOS charge pump bootstrap boosted high-arm switch (N-Channel to maintain a relatively small Rds(on), and at the same time, it is more convenient to measure the voltage of the thermocouple during feedback)
Note that when installing the handle vibration switch, the pins on the gold side should face upward, otherwise the sensitivity will be extremely poor.
Here are the steps to assemble the handle-front panel:
How to connect the slots on the rear panel
The above is the general installation process
For program location, please visit Wagminator's EasyEDA project
