太白金星
1.54 double-layer plug-in board - slave board
  • Thanks to Lichuang user @1174247739lc for providing ideas!
  • By adding the lower layer, functions such as ink screen access control keychain, portable small calendar, photo decoration, etc. can be realized.
  • The motherboard can use esp8266, msp430, stm, etc. All can be replaced to expand playability .
  • 2.00mm pins are used instead of the commonly used 2.54mm, because 2.00mm is shorter and takes up less space.
  • The fpc socket is compatible with 34pin and 24pin , and is positioned through silk screen
  • The screen switching function is retained . It is a toggle switch on the micro-ski board. Some boards directly delete the changing function. This board uses a compromise method and uses a 0 ohm resistor instead of the switch. After all, screen switching is not commonly used, but it cannot be left out. Not www
  • The 3-wire SPI and 4-wire SPI switching is also retained , and is switched with a 0 ohm resistor.
  • Thanks to Weixue wiki.
I'll try to answer all your questions as best I can, thanks for the comments!
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 17:56:12
