1. Function description
2. Design features
3. Other instructions
The schematic diagram refers to the designs of many developers at home and abroad.
There is basically no problem with the schematic diagram. However, due to the author's lack of PCB wiring experience, there may be some defects in this aspect. I hope that seniors can improve it.
4. Engineering Bug Records
20200728—BUG—The pin spacing is wrong—2.54 pins cannot be soldered—Unmodified 20200728—BUG—The emulator cannot recognize the ST chip—Solution: Hold both sides of the board and lift the board off the table to identify the chip. download.
5. Project progress
20200728: The board has been soldered and the minimum system is operating normally. The test code is initialized using STM32CubeMX. I simply wrote a test program for flipping the level status of a small light. The download test run was successful. The test video and code will be uploaded later. Other functions have not been tested yet. In addition, I found a problem during welding. The spacing of the pin headers is not 2.54mm . I will modify it in the next version.
