3228
[Tuya Smart] IoT temperature and humidity sensor
picture.png Temperature and humidity sensor reference circuit If the ALERT pin is not used, it should be left floating. The nReset pin should be connected to a resistor with a typical value of 50K. The IIC pin should be connected to a 10k pull-up resistor. picture.png Periodic acquisition timing diagram picture.png,] In the WB3S module, picture.png RXD2 and TXD2 are connected here. The output is to print the module information, and the ADC channel is led out. I think it may be useful in the future for USB to serial port picture.png . Almost every Lichuang event has drawn this one. It is more practical. picture.png The idea of ​​the buzzer is to make the buzzer sound when the temperature or humidity reaches a certain range. will sound, when an alarm is used, the module used for this Lichuang activity graffiti uses an MCU development solution, so the key parts need to be on the microcontroller. This activity has taught me a lot, thank Lichuang!
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:17:06
