elleny
WS2812/SK6812 light board based on STC microcontroller
Hardware
The microcontroller uses STCsop8 microcontroller (STC8G1K, STC15w104), which can be customized by programming.
The lamp beads are made of ws2812 and sk6812 colored lamp beads. Each ten lamp beads are in a group, with a total of three groups.
Reserved pin header, you can download the program through the serial port or communicate with the light board main control MCU through the serial port.
Equipped with a fuse, which can effectively prevent accidents caused by short circuit when connecting to a high-power power supply
With three buzzers, the sound can be emitted through the push-pull mode of the microcontroller, and the volume can be adjusted through the duty cycle.
software part
Adopting graphical programming, it is easy to understand and operate.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:36:34
