红水杯
LM5050_ORING ideal diode
LM5050 ultra-low voltage drop ideal diode module
  • It can be used in N+1 power supply system or Buck synchronous rectification topology DC-DC to charge the battery to prevent the battery current from flowing back into the synchronous buck module and causing the module to burn.
  • Voltage range: 6-70V (Using a jumper pin to connect "EXT" and connecting an external power supply allows the ideal diode to operate at a lower voltage)
  • Maximum bus current: 30A (BSC030N08 *2)
  • The power input must be connected to the common ground of the power system! Regardless of external power supply, otherwise the ideal diode will not work.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 16:33:10
