aytwartoofyoroo
144LED array development board based on IS31FL3732
Based on the test version of IS31FL3732, there have been a lot of ships recently, and they all use this kind of chip, so I just made it and played with it, hehe~
SDB is the enable pin, active high. The power supply voltage is 3.3V. The chip address is determined by the address jumper. The lamp position naming is the same as the official manual (pdf file below), which is easy to find. You can also modify the file yourself.
The PCB file is drawn for AD16. I was not used to the EDA traces, so I left it. The PCB file has been printed and verified.
9.1 Supplement: K70 MK2 LDE line bitmap
9.10 update: 3D packaging update
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 19:38:45
