ohahaha
USB to Ethernet circuit board based on RTL8152B, compatible with SR9900
Universal RTL8152B USB to Ethernet circuit board, compatible with SR9900
Pid Vid MAC product device name, serial number, LED configuration and other information can be programmed through PGTOOL software. The information is stored in the EFUSE inside the chip, with a limit on the number of write modifications; it can also be stored in an external eeprom chip. This project does not have this part of the circuit.
ISO files can be uploaded to external FLASH memory through PGTOOL software. When the computer does not have a driver, the chip will automatically pop up the USB virtual optical drive after 10 seconds.
If the chip's Vid and Pid are not the default 0x0BDA, 0x8152. If the PGTOOL software cannot recognize it, you can first modify the vid and pid in the configuration file to be consistent with the hardware, and then burn it to the default vid and pid. Convenient automatic driver loading
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 18:04:49
