走马观花
2.8-inch TFT color display
  • This module uses a 2.8-inch TFT color LCD screen. The module is compatible with the 2.8-inch TFT LCD screen of Punctual Atom. The screen resolution is 320x240 and the driver IC is ILI9320/9325/9341.
  • Technical Parameters:
  • 1. Working voltage: 2.5 ~ 3.6 V
  • 2. LCD size: 2.8 inches
  • 3. Resolution RGBx320x240
  • 4. Driver IC: ILI9320/9325/9341
  • 5. Display size: 57.6mm x 43.2mm
  • 6. Color depth: 16 bits
  • 7. Backlight working voltage: 3.3V/5V
  • 8. Touch screen: tempered display
  • 9. Compatible with Punctual Atom 2.8-inch TFT
  • 10. Module size: 82.6mm x 51.1mm
  • PCB blank board:
  • Will be updated later
  • Weld the real thing
  • Module size diagram:
  • Pin description
  • Serial number|Pin name|Description|
  • 1 CS LCD chip select signal (active low level)
  • 2 RS command/data control signal (0, command; 1, data;)
  • 3 WR write enable signal (active low level)
  • 4 RD read enable signal (active low level)
  • 5 NRST reset signal (active low level)
  • 6~21 D0~D15 bidirectional data bus
  • 22, 26, 27 GND ground
  • 23 BL backlight control pin
  • 24, 25 3.3V module power supply voltage 3.3V
  • 28 5V Backlight voltage 5V
  • 29 MOSI touch screen IIC _SDA signal
  • 30 MISO serial signal input terminal
  • 31 PEN_T touch screen interrupt signal
  • 32 NC free leg
  • 33 T_CS reset signal
  • 34 CLK touch screen IIC_SCL signal
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-09 02:08:53
