The actual test shows the 22W icon SV fast charging protocol.
IP5358 has a built-in fuel gauge function for accurate battery power calculation.
IP5358 supports external pin to select LED mode or digital tube mode (please refer to the button mode selection section).
IP5358 supports automatic selection of 4-lamp, 2-lamp and 1-lamp modes.
IP5358 supports 188 digital tubes to display power.
(LED4 pin is pulled up to VCC and recognized as LED light mode).
A separate digital tube with a percentage lightning mark is required. There will be some minor problems with the digital tube display. The corresponding 1 and % are connected in parallel, and lightning is compounded with other ios. 5358 is an independent fast charging signal
