aytwartoofyoroo
ANT BBPS: A small, portable and elegant open source OLED breadboard power supply (schematic, source code)
The ANT BBPS is a small and elegant breadboard power supply (BBPS) designed to connect to the end of any M102 breadboard. Its unique shape plugs directly into the power connection pins without interfering with anything else.
But that's not all! ANT BBPS displays voltage, current and power on an OLED display. It features digitally controlled current limit, wide input voltage range and up to 12 V DC output. It also has two input connections, a USB type-C connector and a screw terminal. A USB input means a battery pack can easily be used as your power source, and the screw terminals allow any other input source to be connected, such as AA and 9 V batteries, or even that old 7 V wall adapter you might have lying around.
Features and specifications
- 4.0 V DC - 13.0 V DC input
- 1.8 V DC - 12.0 V DC @ 1000 mA (12 W) output
- Voltage output is set in 10 mV increments
- Digitally controlled current limit
- Current limit set in 50 mA increments
- External input connection
- Specifically designed for M102 breadboard
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-05 18:23:25
