aerobotics
An open source iCE40 FPGA development board designed for teachers and students
Digital Logic Design Made EasyAre you ready to venture into the brave new world of digital logic design? The iCEBreaker FPGA board is specifically designed for you. It works out of the box with the latest open source FPGA development tools and next-generation open CPU architectures. The iCEBreaker is easily expandable through its Pmod connectors, so you can make use of a large selection of third-party Pmod modules, as well as the several new Pmods we’ve specifically designed for it. There’s ample documentation, including well-tested workshop curricula, video tutorials, and datasheets. iCEBreaker V1.0b Features & SpecificationsLattice iCE40UP5k FPGA5280 logic cells (4-LUT + Carry + FF) 120 Kbit dual-port block RAM 1 Mbit (128 KByte) single-port RAM PLL, 2 x SPI, 2 x I2C hard IPs Two internal oscillators (10 kHz and 48 MHz) for simple designs Eight DSP multiplier blocks for signal processing such as audio synthesis and even software defined radio Low power consumption ideal for battery-powered applications Three 24 mA drive and 3 x hard IP PWM (can drive RGB LEDs and small motors) Plentiful, fast storage128 Mbit (16 MB) quad SPI double data rate (QSPI-DDR) flash Example: can stream video to LED matrix Lots of I/OThree pins (header) for RGB LED Two on-board LEDs One UART, RX pin and TX pin accessible via virtual (USB) serial port One pushbutton Two available Pmod connectors (16 x pins total) One breakaway Pmod (8 x pins) Pre-wired, breakaway Pmod moduleInput and output user accessible and usable in your own hardware design Five LEDs in a star pattern Three push buttons Capable enough to host CPU softcorespicorv32 picosoc RISC-V and others On-board FPGA programmer and USB-to-serial adapterCompatible with IceStorm iceprog tool Easy, driverless connection as a serial device to host computer USB high speedOn-board FT2232 USB chip Up to 480 Mbit/s interface to host computer Buying GuideIf you’d like to work through, participate or organize an iCEBreaker FPGA workshop, please use this brief buying guide below: WorkshopItems neededWTFpga workshopiCEBreaker, DIP Switch Pmod, iCEBreaker 7-Segment PmodiCEBreaker workshopiCEBreaker, iCEBreaker 7-Segment Pmod x2Pmod Connectors & Breakaway PmodThe iCEBreaker FPGA board has three standard Pmod connectors, which makes for a wide range of expansion options since Pmod is a standard followed by several hardware manufacturers. This gives you access to a massive library of modules — no matter what your project, you’re sure to find a Pmod for it. For examples of existing Pmods, check out the Digilent online store. For several use cases, we have also developed our own Pmods and we keep adding more as they are developed. In this campaign, we are introducing a seven-segment display Pmod, a DIP switch Pmod, an LED panel driver Pmod, and an HDMI output Pmod. iCEBreaker V1.0b and a selection of Pmod boards The iCEBreaker FPGA board comes with a tabbed, breakaway Pmod with three pushbuttons and five LEDs. You can use the breakaway Pmod to explore FPGAs right away, without any soldering, or you can break it off and use the Pmod connector for another Pmod. Each iCEBreaker comes with headers for all its connectors Open Source ToolchainThe iCEBreaker FPGA prototypes are already supported by the following open FPGA design tools: Yosys: framework for Verilog RTL synthesis Arachne-pnr: place and route tool for the iCE40 family of FPGAs nextpnr: vendor-neutral, timing-driven FPGA place and route tool IceStorm: tool for analyzing and creating bitstreams for iCE40 FPGAs icestudio: IceStorm-based visual editor for FPGA boards Amaranth Screenshots of icestudio (left) and nextpnr (right) iCEBreaker Block Diagrams iCEBreaker V1.0b legend (top) iCEBreaker V1.0b legend (bottom) iCEBreaker functional block diagram WTFpga WorkshopThe main motivation for the iCEBreaker is to serve as a good educational board. To validate this, we used early prototypes of the iCEBreaker to teach a new version of Joe Fitz‘s WTFpga workshop at the 2018 Hackaday Superconference in Pasadena, California. Joe had originally developed his WTFpga workshop around a Xilinx development board. We were able to convert his workshop to the iCEbreaker quickly by adding two Pmods to the board: a seven-segment display Pmod and a DIP switch Pmod. Side-by-side Pmods: seven-segment display (above) and DIP switch (below) The conversion from a Xilinx target board to the iCEBreaker resulted in much faster synthesis times and simpler workshop instructions. The workshop went well — it sold out early on (and there were many additional walk-ins beyond the initial 30 spots) and workshop participants reported being happy with their experience. All the WTFpga workshop materials are available on GitHub. The workshop is self-directed, so you can go through it on your own or with friends by buying the "iCEBreaker WTFpga Kit," which includes all the materials you’ll need. We also have a discounted ten-pack, so you can run the workshop at your company or at your hackerspace! HDMI Output Pmod HDMI Pmod The iCE40UP5k FPGA on the iCEBreaker is fast enough to output 720p video! Based on the amazing Pmod design by Kevin Hubbard from Black Mesa Labs, we developed a new HDMI Pmod. The "iCEBreaker HDMI Kit" pledge level of this campaign contains a 12 bits/pixel HDMI output Pmod that plugs into the two spare Pmod connectors on the side of the iCEBreaker board. We have several examples already available for the HDMI Pmod, including the original design by Kevin that outputs a 800 x 600 resolution test pattern, and a 720p pattern generator by Micah Elizabeth Scott aka. Scanlime. The iCEBreaker + HDMI Ouput Pmod displaying Scanlime’s 720p video pattern generator Our HDMI output Pmod and accompanying examples are a convenient starting point for exploring HDMI video generation using an interface similar to VGA analog output. The possibilities are endless, from retro computer video output to custom game console design to video art installations. LED Panel Driver Pmod iCEBreaker V1.0b with LED panel and driver Pmod Large video billboards, like those on the sides of buildings in Times Square, are built from small RGB LED tiles. Thanks to recent economies of scale, the tiles are now quite affordable and are a great, fun way to play with animation and video. Our LED panel driver Pmod provides an interface from the iCEBreaker board to an LED panel equipped with a standard HUB75E connector. LED panel driver Pmod LED Panel Example 1: kbob’s eye candyBob Miller (a.k.a. kbob) has created a collection of small eye candy animations while learning verilog. iCEBreaker V1.0a running iCEBreaker Candy munch2 (credit: Bob Miller) LED Panel Example 2: tnt’s on-the-fly and recorded video playbackThis impressive flexible design by Sylvain Munaut (a.k.a. tnt) can do all sorts of things, like generate pixel data on the fly in a similar way as a graphics card generates shaders, play video frames from the iCEBreaker’s on-board flash, and display video streamed from a host computer over USB to the FPGA. It is an ideal design if you are planning an LED panel project and want to customize the way the panels are driven. iCEBreaker V1.0a playing Nyan Cat video from on-board flash (credit: @tnt) iCEBreaker V1.0a playing a video pattern generated in real time (credit: @tnt) iCEBreaker V1.0a Rickrolling from a host computer over USB (credit: @tnt) LED Panel Example 3: Scanlime’s icestudio driverMicah Elizabeth Scott (a.k.a. Scanlime) created an amazing design in icestudio to drive LED panels. iCEBreaker V1.0a playing feedback munching square animation (credit @scanlime) The design is modular and can be visually explored in icestudio. The goal is to create a small, easily modified pixel rendering engine. Micah captured the whole design process on video in multiple eight-hour sessions that are available to watch in their entirety! We highly recommend that you subscribe to Micah’s YouTube channel. She is creating engaging and interesting educational content. With the "iCEBreaker LED Panel Kit," you can follow her adventures from home. Episode 1: Early look at iCEBreaker FPGA with LED matrix / open tools for gateware with Python [2018-10-22] Episode 2: LED matrix on the iCEBreaker FPGA with the icestudio visual editor plus Verilog [2018-10-23] Episode 3: Visual FPGA design with icestudio and Verilog, iCEBreaker LED matrix continued [2018-10-24] Episode 4: Quiet FPGA stream / LED matrix continued / icestudio and verilog [2018-11-9] Episode 5: FPGA Saturday / icestudio and verilog / LED matrix driver and GPU parts / the fun part? [2018-11-10] Scanlime’s ledmatrix design in icestudio (left) and screenshot from her live stream (right) Comparisons iCEBreaker TinyFPGA BXTomu FPGALattice ICEstickUPDuino v2.0ICE40UP5K BreakoutAlhambra IIICE40HX8K BreakoutLicenseOSHW OSHWOSHWClosedClosedClosedOSHWClosedSchematics Published?Yes YesNot YetYesYesYesYesYesDesign files Published?Yes YesNot YetNoYesNoYesNoFPGAModeliCE40UP5K iCE40LP8KiCE40UP5KiCE40HX1KiCE40UP5KiCE40UP5KiCE40HX4K(8K)iCE40HX8KLogic Capacity (LUTs)5280 768052801280528052803520 (7680)7680Internal RAM (bits)120k + 1024k 128k120k + 1024k64k120k + 1024k120k + 1024k80k128kMultipliers8 0808800PeripheralsUSB InterfaceFTDI 2232HQ On FPGA BootloaderOn FPGA BootloaderFTDI 2232HLFTDI 232HQFTDI 2232HLFTDI 2232HQFTDI 2232HLUSB HS FIFO/SPI interface to the FPGAYes through Jumper Mod NoNoNoNoNoNoNoUSB Serial (UART) interface to the FPGAYes NoNoYesNoYesYesYesGPIO inline termination resistorsYes 33 Ohm NoNoNoNoNoYes 300 OhmNoUser IOs27 + 7 41 + 24 + 2183434 + 22090 + 10Pmod Connectors3 0010100User Buttons1 Tact + 3 Tact on Breakoff Pmod 1 CRESET2 Capacitive004 DIP2 Tact0User LED2 + 5 on Breakoff Pmod 1051 RGB1 RGB88Indicator LEDPWR, CDONE PWRCDONE, FTDI-TX/RXPWR, CDONEPWR, CDONE, FTDI-TX/RXPWR, CDONEOnboard Clock12 MHz MEMS Shared with FTDI 16 MHz MEMS12 MHz MEMS12 MHz MEMS? Shared with FTDI12 MHz MEMS? Shared with FTDI12 MHz MEMS? Shared with FTDI12 MHz MEMS Shared with FTDI12 MHz MEMS? Shared with FTDIFlash128 Mbit QSPI DDR 8 Mbit SPI16 Mbit SPI32 Mbit SPI32 Mbit SPI32 Mbit SPI32 Mbit SPI32 Mbit SPIFPGA Power DeliveryDedicated GND/Power PlanesYes YesNoYesNoYesYesYesDedicated FPGA Bypass Capacitors19 8918219??IO GND Connections11 614382220SoftwareOpen Source ToolchainYes YesYesYesYesYesYesYesAPIOYes YesYesYesYesYesYesYesicestudioYes YesNot YetYesYesYesYesYesAmaranthYes YesYesYesYesYesNoYesManufacturing Process1BitSquared has most of its PCBs manufactured in the US. We order our PCB designs through OSH Park, a PCB fabrication company located in Portland, Oregon, USA. We order our parts through a combination of US and Chinese companies, comparing the prices and shipping times to make the most sensible purchasing decision. After all of the parts are ordered, 1BitSquared assembles all of our hardware in house on our pick-and-place machine. iCEBreaker V1.0b pre-production on the 1BitSquared pick-and-place machine iCEBreaker V1.0b pre-production batch Support & DocumentationThe iCEBreaker community is already creating interesting Pmods, designs and applications such as iPod nano display Pmods, network interface Pmods, and much more. We welcome you to drop in to the iCEBreaker Gitter channel to talk about your ideas and ask questions! For more detailed and technical discussion of the hardware features, please visit our GitHub iCEBreaker repository. We are also in the process of setting up a wiki and forum for the iCEBreaker platform. Everyone, backer or not, is welcome there to collect and share information about open source FPGA development.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-08 19:00:03
