ohahaha
CVBS camera
Introduction: A CVBS camera motherboard. It uses Korean Pelsol sensor PC1058D, which has high resolution and low illumination. The camera effect is clear.
1. Product introduction:
2. Application scenarios:
Suitable for vehicles, security monitoring, video doorbells, drones and other fields.
3. Product Overview:
A CVBS camera motherboard, using the camera sensor PC1058D from South Korea. The motherboard PCB size is only 16x16mm, which is very suitable for miniaturized products.
4. Product specific parameters:
1. Sensor target surface size: 1/3 inch
2. Input voltage: 3.0-3.3V/DC.
3. Current ≤120mA/3.0V/DC
4. Video output: CVBS, 1Vp_p±10% ,75Ω
5. Camera resolution: 960*576.
6. Scale line: Supported.
7. Horizontal mirror/rectangular image: optional
8. Standard PAL/NTSC: optional
9. Working temperature: -30.0℃~+80℃ .5
. Product usage tutorial:
1. FLASH needs to burn the program before mounting.
2. See "Reference Design Download" on the front of the motherboard.
3. See "Reference Design Download" on the reverse side of the motherboard.
4. Solder 3 external connecting wires. The solder points are "Video Output", "GND" and "3.3V".
5. R19, R17, and R15 are function-selected resistors (0R/0402), which can be selected according to actual needs.
6. Install the lens holder and lens, connect the video signal cable to the CVBS monitor, turn on the power, adjust the focus, and it can be used normally.
6. Remarks:
1. This product needs to be burned with program code before use. The code and burning tool methods are explained in the attachment.
2. Resistors, capacitors and crystal oscillator FLASH can be purchased directly at Jialichuang Mall or purchased by yourself.
3. The lens holder, lens and sensor are not included in the BOM and need to be prepared by yourself. There is a reference purchase link in the attachment.
Accessories description:
1) Lens mount specifications: M12, inner frame 10x10mm, outer frame: 11.5x11.5mm.
2) Lens specifications: wide-angle lens (lens can be selected according to actual needs).
4. Hardware and program codes are released for free. Those who are interested can DIY and make boards directly at Jialichuang.
5. The cost of making a sample is about 40 to 50 yuan.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 23:20:35
