念慈菴
USB to CAN debugger
Introduction: USB to CAN low-cost solution
1. Product introduction
Although the USB to CAN solution currently on the market is very mature, it is also relatively expensive. The USB to CAN solution of this solution is low cost and easy to use. It requires no driver for WIn8 or above. Usage
2. Application scenarios
a: Used for communication between USB devices and CAN devices
b: Used as daily debugging tools for engineers
3. Product Overview
a: This solution can achieve two-way communication between USB devices and CAN devices
b: The principle is Between the USB device and the CAN device, the STM32F0 microcontroller is used for protocol analysis and forwarding. With the dedicated host computer software, you can use
c: The host computer adopts the winUSB driver-free solution and USB bulk double buffering mode. The actual transmission performance far exceeds those Virtual serial port USB-CAN
d: Flexibly choose whether to connect 120R terminal resistor through jumper cap
e: WIN8 or above system driver-free
4. Product parameters
Input voltage: 5V
Input interface: TYPE-A
Output interface: 3.08x2P plug-in wiring Is the terminal
isolated: No
Main chip: STM32F072CB
CAN transceiver chip: TJA1050
Number of CAN channels: 1
PCB size: length x width 48mm * 30mm
5. Usage method
a: Connect STLINK or JLINK to the "firmware programming port" of the module, and program Firmware "Firmware.hex"
b: Connect the USB end to the computer, and the CAN output end to the corresponding CAN device. Select whether the jumper requires a 120R resistor according to your own needs. Turn on the host computer and you can use
it. c: Detailed usage of the firmware and host computer For details, please see the attachment "Firmware + Instructions for Use"
6. Remarks
1. This module is software + hardware and needs to be programmed before it can be used. For the required files and tutorials, please see the attachment "Firmware + Instructions for Use"
7. Test
video , connect the USB to CAN of this solution to another CAN analyzer, and realize data sending and receiving to each other through PC USB-CAN analyzer-this solution USB to CAN-PC USB
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-05 08:54:44
  • Did you feel disappointed after watching Avengers 4?
  • Trends in charging inverters
  • HDB3 encoding and decoding principle
  • Global variables
  • Help! Which sensor is best to use to make the second robot follow the path of the first robot?
  • Focus on IC design base model innovation
