smallembedded
High speed uncontrollable remote control car
The remote control car is too slow! ! ! I can't stand it! Make one yourself! Just go ahead and complete this super powerful work based on ARDUINO mobile phone Bluetooth control, all handmade. Welcome to learn. to avoid detours!
Author: Walking on the Edge of the Universe
https://www.bilibili.com/read/cv6217381
Source: bilibili
This is the 11th generation finished car. The performance has been greatly improved. The project has released the schematic diagram and PCB. You can download and use it yourself.
#include
#define LED     2
#define NUM_LEDS    6
CRGB leds[NUM_LEDS];
#define PINX A5
#define PINY A3
#define PINKG A1
#define PINLU 5
#define PINLD 6
#define PINRU 10
#define PINRD 9
int TZ=200;//速度调整
int speedcal=0;
int Direction;//方向原始数据
int correctionXR;//x修正后的X
int correctionXL;//x修正后的X
int spd=255;
unsigned long Speed;
unsigned long KGSG;
void motorprint();
void motorcontrol();
void dealX();//X方向调整
void motorprint()
  pinMode(PINX, INPUT); //设置引脚为输入模式
  pinMode(PINY, INPUT); //设置引脚为输入模式
  pinMode(PINKG, INPUT); //设置引脚为输入模式
  pinMode(A0, OUTPUT); //设置引脚为输入模式
  pinMode(LED, OUTPUT); //设置引脚为输入模式
    pinMode(PINLU, OUTPUT); //设置引脚为输出模式
    pinMode(PINLD, OUTPUT); //设置引脚为输出模式
    pinMode(PINRU, OUTPUT); //设置引脚为输出模式
    pinMode(PINRD, OUTPUT); //设置引脚为输出模式
    digitalWrite(PINLU,LOW);
    digitalWrite(PINLD,LOW);
    digitalWrite(PINRU,LOW);
    digitalWrite(PINRD,LOW);
void motorcontrol()
  if ((TZ>5)&&(Speed>Direction))
     speedcal=(Speed-Direction);
     analogWrite(PINLU,constrain(Speed,0,254));
     analogWrite(PINLD,constrain(Speed,0,254));
     analogWrite(PINRU,constrain(speedcal,0,254));
     analogWrite(PINRD,constrain(speedcal,0,254));
  else if (TZ<-5)
  //  speedcal=constrain(map((Speed+Direction),Speed,310,Speed,250),Speed,250);
    speedcal=(Speed+Direction);
    analogWrite(PINLU,constrain(speedcal,0,254));
    analogWrite(PINLD,constrain(speedcal,0,254));
    analogWrite(PINRU,constrain(Speed,0,254));
    analogWrite(PINRD,constrain(Speed,0,254));
  else
    analogWrite(PINLU,constrain(Speed-5,0,254));
    analogWrite(PINLD,constrain(Speed-5,0,254));
    analogWrite(PINRU,constrain(Speed+1,0,254));
    analogWrite(PINRD,constrain(Speed+1,0,254));
void setup()
 // Serial.begin(19200);
   motorprint();
   FastLED.addLeds(leds, NUM_LEDS);
   digitalWrite(A0,HIGH);
   for(int i=0;i<6;i++)
    leds[i] = CRGB ( 225,255,255);
   FastLED.show();
void loop()
  /*Speed =pulseIn(Y, HIGH,80000);
Direction =pulseIn(X, HIGH,80000);
 KGSG = pulseIn(KG, HIGH,80000);*/
  KGSG = pulseIn(PINKG, HIGH,80000);
  if(KGSG<1100)
  spd=3;
    leds[i] = CRGB ( 0,0,255);
   FastLED.show();
  else if(KGSG<1700)
  spd=2;
    leds[i] = CRGB ( 225,0,255);
   FastLED.show();}
  else if(KGSG<2000)
  {spd=1;
    leds[i] = CRGB ( 225,0,0);
   FastLED.show();
  else
  spd=255;
  Speed=(constrain(map(pulseIn(PINY, HIGH,80000),989,1968,0,250), 0, 250)/spd);
  Direction =constrain(map(pulseIn(PINX, HIGH,90000),998,1982,-TZ,TZ),-TZ,TZ);
  if (Speed<20)
    Speed=0;
    digitalWrite(A0,LOW);
    motorcontrol();
  else
       motorcontrol();
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-15 13:12:53
