newrudeman
HDMI3 input 1 output switch AG7111 chip verification board
0. Open the project and click the [Open Editor] button in the upper right corner
1 Introduction
Solution verification board using AG7111 3-in-1-out HMDI switching chip
It is also a follow-up to the last audio switching. Because there are many devices, it is troublesome to unplug and plug in HDMI cables every time, so I did this.
There are also audio switchers and USB+HUB 4 in and 4 out switches. Welcome to jump to each switch project:
Audio 4-to-1 switcher (common ground)
USB HUB switch 4 in and 4 out
HDMI3 in 1 out switch AG7111 chip verification board (this project)
The chip is about 10 yuan a piece, and the peripherals are actually less than 15. Jack Ma sells 3 in 1 out online for about 70+ soft sister coins.
2.Principle
The chip specifications have been given, but to be honest, there are no typical application diagrams in the specifications . They are all drawings made by myself. There may be some errors in them. If anyone knows, please point out the errors, thank you ~
The schematic diagram is still relatively simple, but there are a few points that need attention:
  • The output CK+- needs to be connected to a 3.3V pull-up
  • The TXISEL pin is left floating for hardware control. There is no MCU control here, it is pure hardware. If there is no L1 magnetic bead, a 0 ohm resistor can be used. MCU control is to give different voltage values ​​to the TXISEL pin to switch different ports.
3. Shell
Use Lichuang Professional Edition to draw, providing shell
Use 3D Monkey White Whoring Shell, thanks to 3D Monkey (dog)
The casing is drawn higher and the keys, switches and LED lights can be raised slightly for welding
4. Precautions for use
USB5V is reserved. In fact, the 5V of the HDMI output device can also be used to supply power to the board. If you find that the light does not light up, or the output signal flickers and the screen changes, you need to connect a 5V power supply.
The measured HDMI direct connection has no problem, and HDMI to DVI has no problem. HDMI to VGA has insufficient power supply and requires an additional 5V power supply.
Improve:
  • You can walk the same length
  • Replace LOD with low pressure difference
  • Also replace the diode with a low voltage difference one.
  • Video signal string beads
  • Do 100 ohm impedance matching on the HDMI signal cable (jlc can do it, but it costs extra, the prostitutes do it at will, and they don’t do certification anyway)
In addition, you can make a 5-in, 1-out, 7-in, 1-out solution. Just stack chips, but it requires MCU control. When I have time, I am making a 5-in, 1-out, 7-in, 1-out solution.
4. Demonstration video
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:22:08
