kLGG3T
Electric solder paste extruder dot solder paste machine dispenser
Features: low cost
           No need for microcontroller
           The center of gravity is closer to the hand, which is more comfortable
           Electric medium-sized batches are more labor-saving
           Simple structure and easy to reproduce
Disadvantages: Small batches are not as easy to use as manual
           The battery life is only about three hours which is a bit short.
           Not very beautiful
           The amount of solder paste produced is greatly affected by the temperature of the solder paste.
It uses a 200mah lithium battery and can be used wirelessly or plugged in.
Using two ne555, you can set the extrusion time (0.2-0.4s) and the withdrawal time (0-0.2s) respectively.
The purchasing list will be placed in the BOM
STL.zip
Fusion360 source file.zip
BOM_Board1_1_Schematic1_2022-04-25.csv
58391
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:16:17
