3228
ESP32-PICO-KIT
The power supply uses a TP4054 lithium battery charging chip to charge the battery, and then converts the battery to 3.3V through LDO to power the MCU. It integrates an independent 3.3V peripheral power supply control MOS to facilitate low-power control.
The onboard CP2102 chip supports serial port downloading, printing and debugging.
Two onboard buttons P0 and P2
Onboard patch ceramic antenna and matching circuit
Onboard NTC temperature measurement circuit
Onboard battery voltage measurement circuit
The onboard 0.96 ST7735 RGB 80*160 pixel LCD screen is connected to the corresponding pins through 6 jumper pads
The onboard VL6180 proximity sensor and MPU6050 attitude sensor are connected to the corresponding I2C pins through 2 jumper pads
Lead out most of the GPIO, and disconnect the jumpers on some peripheral pins so as not to affect the normal use of the pins.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 21:12:04
