sigma
Yuzuki LOHCC HDMI loop-out capture card
Low-cost HDMI loop-out capture card based on MS2109 + MS9332, only costs 34 yuan.
  • Support HDMI 4Kx2K@30Hz and HDMI 2.0, YCbCr420 4Kx2K@60Hz loop out
  • Supports 10/12/16-bit color depth loop out
  • Loop-out adaptive input equalization
  • Loop out integrated HDCP Key
  • Comes with EDID RAM
  • Type C USB2.0 interface
  • Full height HDMI
  • DVI 1.0 compatible
  • Supports acquisition of HDCP 1.4 (the firmware does not provide HDCP keys, please apply for the keys yourself for details)
  • Support YUV&JPEG output
  • UVC 1.0 compatible
  • Support audio collection
  • Support video capture
  • Maximum video input 3840x2160@30
  • Maximum output resolution 1920*1080@30
Let’s take a look at the pictures:
After burning the firmware, 2 devices will be displayed, one for audio input and one for video input.
Supported USB output resolution table
Firmware burning method:
Use EEPROM programmer to flash into EEPROM and then solder
Unfortunately, I couldn't find a public version of the MS8003 code, but it's not expensive to buy a burned-in set.
other
YuzukiHD open source hardware and software exchange group: 685554363
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-05 18:22:56
  • Op amp classic
  • IGBT application circuit for high current drive
  • Detailed explanation of the role of 0 ohm resistor
  • Brushless drive solution for circuit board
  • INOUT pin: How to use it in FPGA
  • 【White Paper Sharing】Paving the way for wireless capacity expansion
